Automatic Transmission rebuild advice
Old 10-11-2010, 12:00 PM
93runnerguy's Avatar
Exclamation Automatic Transmission rebuild advice
Alright so anyone who has been looking at my threads i have been having alot of problems with my tranny, i recently picked up another tranny for 80 bucks and they guy said the only problem was 2nd gear was slipping, i now own 3 different trannys, i want to just switch out 2nd gear to save money other then having to sell my arm and leg to a tranny shop, which wouldnt even work right now since i am on disability and it doesnt pay to well and i have other bills to pay, does anyone know how hard this is going to be and does anyone know of any sites that gives step by step instructions with very good diagrams, i want this to goes as painless as possible any advice and help would be greatly appreciated!! thanks!
Old 10-11-2010, 04:15 PM
so i was doing some more reading and i found the problem could just be a solenoid problem, any info or other help or suggestions would be greatly appreciated! thanks all!
Old 10-11-2010, 05:53 PM
T-1000's Avatar
You're biting off a lot with an automatic trans rebuild. They are extremely complex, even compared to manual transmissions. On top of that, the A340H is more complex than many other autos, since the hydraulic transfer case is basically another whole little trans.
There are plenty of resources for rebuilding manuals, because they're relatively simple.
I don't know of any A340H rebuild guides, but I would go very slow, take a ton of pictures, and label everything.
Here's some great info, but it isn't really a guide.
http://rigs.corequipment.com/Cebby/9...20Transtec.pdf
Old 10-11-2010, 08:02 PM
rustypigeon's Avatar
If your second gear is slipping, you don't just "switch it out". There is no "second gear" but rather a group of planetary gear that are held together or released to get various gear ratios.
If the second gear was slipping, and that was the only problem with the transmission, The No. 1 One Way Clutch would be highly suspect.
What exactly is wrong with the transmission on your truck?
Old 10-11-2010, 10:27 PM
the tranny in my truck now is all F'd up. the transfer case is all messed up and so are different gears, so i bought a new one and the guy said the only issue is that second is slipping, i havent put it in though because i want to make sure it is fixed before i install it, and with some research, it could be the solenoids, is that true or was i misled?
Old 10-12-2010, 04:57 AM
Bad solenoids cause certain gears not to work at all. If it is slipping, you either have worn out clutches, or low line pressure caused by a leak or loose clearances somewhere in the hydraulic circuit.
If it has been slipping for a while, you will probably find bits of clutch material in the pan.
BeMiceElf
10-10-2015 09:40 PM
Poncho0206
07-10-2015 06:21 PM
shar
07-09-2015 12:38 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Automatic Transmission rebuild advice
