Auto Trans suddenly revs like in nuetral
Old 10-14-2013, 08:07 PM
imcraig2's Avatar
Hey guys got a 92 sr5 4x4 pickup that is starting to give me some issues. I will be driving along and all of the sudden it acts like its in nuetral and just whines out then i will pull over to the side of the road, turn the truck off and on again and it will work fine again for a bit. any suggestions please. i believe the speed sensor was changed out about two years ago. I found a lot of posts about the o/d issue and i thank you. I am also having the same issues as others are with the overdrive not working when cold. looking into that one tommarrow with the sensors and thermostat and such.
Old 10-14-2013, 08:17 PM
Kiroshu's Avatar
Check Automatic Transmission Fluid level.
Old 10-14-2013, 08:23 PM
HighLux's Avatar
Any slippage is gear is either low fluid or burned clutch pack or a burned od band.
If its not low on fluid.....your trans is toast.
Go check the trans fluig.....wipe the fluid on a clean paper towel...and post a pic of the paper towel.
Old 10-14-2013, 08:35 PM
imcraig2's Avatar
I changed the fluid and filter today was not bad and was filled to proper level prior.
akamon808
3.4 Swaps
12-16-2015 08:45 PM
D.B.T. 87 4x4
07-20-2015 04:51 PM
andrewtexas123
07-14-2015 04:29 AM
mengquis
07-13-2015 10:39 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Auto Trans suddenly revs like in nuetral
