ATF leaking from bellhousing
Old 07-25-2007, 06:00 AM
jht3's Avatar
what does this mean? transmission shifts like normal, but there's a slow drip from the seam where the bellhousing bolts to the block, down onto the diff, then onto the ground. it's making quite a mess
119k on the A340H tranny
Old 07-25-2007, 06:49 AM
eric-the-red's Avatar
Probably the front seal on the tranny is leaking. Check the fluid level more frequently. A small drip is just messy but if it gets worse it should be replaced.
Old 07-25-2007, 07:11 AM
jht3's Avatar
level is OK at the moment
the seal is replaceable? i looked in my FSM, and didn't see anything about servicing the seals
Old 07-25-2007, 07:43 AM
scrid's Avatar
atf leak
Oh it's replaceable, not fun though. Gotta pull the engine or trans as you know.
Here is a pic of my old one before replacing it.
Old 07-25-2007, 08:47 AM
jht3's Avatar
ok, great. i'll watch the leak and if it gets worse i'll drop the trans and tackle this....ugh
Old 07-25-2007, 08:58 AM
scrid's Avatar
atf leak
Good luck!
In retrospect I was in a hurry to get my engine installed and went with the Oreilly seal. Looking back I would be more comfortable if I had purchased an genuine Toy seal.
Sorry about the supersize pic everyone.
mizombie
08-25-2015 06:28 PM
Up&Down
08-11-2015 10:04 AM
JHalcyonM
08-04-2015 01:19 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
yourrealdad
07-29-2015 11:08 AM
Quick Reply: ATF leaking from bellhousing
