Is "Arram" a aftermarket throttlebody?
Old 10-17-2006, 04:35 PM
crackerjack's Avatar
I got the big idea to take the pipe that goes from the air flow sensor to the throttle body off. The inside was full of crude so I got the bright idea of spraying some carb cleaner in it. Well that little tube that you push into novel went into intake so I took throttle body off to retrieve said tube.
Now I've went by and called 5 auto parts stores and they all pull up a tb gasket (victory g31142) which is a rectangular gasket. The one that come off engine has an extra part off one side....
Noticing that tb says "Arram" on it is that the stock TB?
Is there a link so I can look up exploded views of engines?
THX 4 any help
Old 10-17-2006, 06:13 PM
well I'm still checkin around...went to L.C. Eng.
When you search there for 92 p/u throttle body gasket
You get a pix of the right one.
Just wondering why I gotta order all the way from Ca. to get right one?
Old 10-17-2006, 07:04 PM
Bill's Avatar
Well, I have 2 throttle bodies: 1 on my 86 Turbo, and 1 from an 87 4Runner(22RE). But have Arran...or Arram(whatever) cast onto them.
What I'm wondering about, is that the 87 has a big 3 on a sticker on it, while the 86 has a 9. Any idea what this is for?
Old 10-17-2006, 07:28 PM
yeah mine has a big 0 sticker... maybe "Arrom" is for the p/u's built in U.S.A. ?
I'm goin into town in the morning and making the rounds again with the pix from LC kinda wondering if I should call to see if they have OEM #
Old 10-17-2006, 07:51 PM
bodo's Avatar
Relax, my stock TB off my 22re has the same word on it followed by Toyota up where it bolts to the plenum with a 7 sticker. Call the nearest dealership, give them your VIN# and cross reference the part# with your local parts house. They'll probably have to order one and they should run around $3.50.
LC is in AZ not CA believe me I know I've spent enough time and money with them that they're now on speed dial and I expect a Christmas card. JK
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
justdifferentials
14
06-11-2017 08:36 PM
SpookyMulder
11-04-2015 11:56 AM
mordell
09-12-2015 10:13 AM
Quick Reply: Is "Arram" a aftermarket throttlebody?
