Argh, clunking, knocking engine
Old 07-10-2007, 01:13 PM
runethechamp's Avatar
Had to pull the old 4runner over this morning and have it towed to the shop. It's making a godawful lot of clunking sounds, stops by itself all the time and I fear the worst. Before it happened, it had a bad regular klunking, knocking sound, but it was definitely worse at light gas or when I was letting go off the gas pedal. Any advice is always appreciated, but I'll probably hear later today or early tomorrow what the dealer thinks it is.
Old 07-10-2007, 01:22 PM
skinnadoor's Avatar
Does it sound like this?
http://www.youtube.com/watch?v=AoHv9H5WBTY
Old 07-10-2007, 01:24 PM
Kaleb's Avatar
I had the exact same problem happen to me about a week and a half ago. Turned out my rear main seal went out and was pissing oil out. I am in the process of finding a remanufactured engine right now. Good luck!
Old 07-10-2007, 01:33 PM
Originally Posted by skinnadoor
Nope. A lot more violent sounds with irregular intervals. Funny thing is, it seems like the engine purrs like a kitten except for the clunking.
Oh, no smoke or leaks as far as I can tell.
Old 07-11-2007, 06:46 AM
MonsterMaxx's Avatar
Rod knock. Common.
After you spend a bunch of time figuring out what a rebuilt 3.slow will cost, do the 3.4.
You'll be way further ahead than if you screw around with the 3.turd
Old 07-11-2007, 07:59 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
"The MonsterMaxx Definitive Guide On Motor Selection"
Chapter 1:
Chapter 2:
See Chapter 1
Chapter 3:
See Chapter 2
Chapter 4:
If you've read this far, consider a labotomy
Chapter 5:
Obviously, the labotomy didn't work. Go back to chapter one.
Old 07-11-2007, 08:59 AM
Rod knock. Common.
Can you explain what this actually is? What does it take to fix it?
Thanks.
Old 07-13-2007, 11:08 AM
After reading a bunch of threads on the subject, I'm rebuilding the baby. Wish me luck. It's a small step up from changing cv boots and rear coils maybe
icentropy
09-16-2020 02:47 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
razorman8669
07-12-2015 12:13 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: Argh, clunking, knocking engine
