alternator not charging!!! need help
Old Sep 10, 2008 | 06:32 PM
nfleuks14's Avatar
bought rmfd alternator frm napa and the alternator is'nt charging.was wondering if it could be anything else besides the alternator....fuse was good but thinking maybe a relay somewhere or something...
Old Sep 10, 2008 | 06:41 PM
DeathCougar's Avatar
ouch. My brains hurt after figuring your typing out.
Have the battery checked. If the battery wont accept a charge, replacing the alterntor won't change anything. And of course check fuses, cables, corrosion, etc. All the normal.
Old Sep 10, 2008 | 07:30 PM
abecedarian's Avatar
the alternator has two connections to the batt- one is the main charging wire from the alt to the batt and the second is a parallel circuit that goes through the ignition and dashboard indicators. there are fuses for both wires.
so check the fuses.
Old Sep 10, 2008 | 08:36 PM
Matt16's Avatar
I'm going going to even bother trying to figure out what the hell you tried to type, but try replacing the brushes. Its a very easy job and costs $10 in parts vs a $200 reman. alt.
Old Sep 10, 2008 | 08:40 PM
here's the english version:
I bought a remanufactured alternator from Napa and the alternator isn't charging. I was wondering if it could be anything else besides the alternator... the fuse was good but I was thinking maybe a relay somewhere or something (was causing the problem).
Old Sep 10, 2008 | 08:42 PM
what is sad, in my opinion, is when there are wiring diagrams (a.k.a. schematics) available for free online, if people would only click on 'search', which show which wire goes where, and what fuse or breaker is installed in the line...
and people still can't figure it out.
and then still wonder why mechanics charge so much for troubleshooting.
Old Sep 10, 2008 | 09:21 PM
space-junk's Avatar
just to tag onto this guys problem, i had to pull the fuse (which was perfectly fine) for the A/C fan(?) because it was not turning off and draining my battery... any ideas? all the wires check out okay...
Old Sep 10, 2008 | 10:18 PM
olharleyman's Avatar
AND SPELL CHECK IS ONLY A CLICK AWAY
Old Sep 11, 2008 | 04:57 PM
schmooot's Avatar
If you just bought the alt can't you bring it back and tell them it doesn't work?
Old Sep 11, 2008 | 05:00 PM
check the switch that activates the a/c fan. it's probably bad, causing the fan to run constantly.
Old Sep 11, 2008 | 10:29 PM
space-junk's Avatar
by switch, do you mean the switch on the dash that says A/C? not trying to be a smart a$$ or anything i just wanna get it right... hmm... last time i had the dash apart it was 1 AM... maybe i didnt hook something up right...
thanks!!
Old Sep 11, 2008 | 10:42 PM
thanks!!
I don't have an electric fan on mine, but our Celica does. So that's what I was thinking, that there's a separate switch for the electric fan, maybe in parallel with the compressor or even linked into the cooling system. I'll check some wiring diagrams later.
Old Sep 11, 2008 | 10:52 PM
space-junk's Avatar
thank you sir! just an FYI, the fan is located on the small radiator that the A/C lines run thru. and its got an expanded metal shroud on it...
nvwiggins
13
Jun 16, 2016 03:05 PM
Chicken12
Oct 14, 2015 03:54 PM
bradahman
Oct 1, 2015 09:24 AM
SCZIG
Sep 20, 2015 09:00 AM
bobjohnson2121
Sep 17, 2015 08:07 AM
