Alternator maybe? or battery? or something else
Old 03-06-2007, 08:51 PM
old4runner's Avatar
Question Alternator maybe? or battery? or something else
My voltage has been slowly dropping as i've run my 4runner over the last week until it is so low the starter won't turn the engine over. So i'm wondering if the battery is not holding a charge or if the alternator is starting to go. My past experience w/ alternator's and batteries has been sudden catastrophic failure so i'm wondering if it is something else. Also when I turn my turn signals on the volt meter starts moving w/ the turn signals...I know this is a clue but i'm not much of an electrical guy so i don't know what it means.
Old 03-06-2007, 09:43 PM
Schralper's Avatar
Charge up the battery. Fire up the truck. Disconnect + lead from battery. If engine continues to run the alternator is fine. If it dies.......
Time for a new alternator.
Old 03-07-2007, 05:20 AM
Nic
Nic's Avatar
How is old is your battery? If it is very old, that might be a clue. I recently had similar symptoms with my car. It would take a while for the battery to go dead. I could charge it up and it would last about a week, but eventually it would go dead again.
Taking a chance it was the battery (since it was ~ 5 years old), I replaced it. It turned out it was. I have never had one do that before.
Old 03-07-2007, 05:47 AM
TNRabbit's Avatar
Could also simply be a bad battey connection; check that first. Remove both clamps, clean terminals & posts & reinstall. WHile you're at it, check all your engine/body grounding straps. These are common problems as vehicles age; connections rust/deteriorate with time.
Old 03-07-2007, 06:17 AM
old4runner's Avatar
thanks i didn't think of that
Old 03-07-2007, 06:18 AM
gilby4runner's Avatar
I may be lazy but take it to auto zone and they can check all of it there.
Old 03-07-2007, 08:46 AM
dlbrunner's Avatar
Check both batterey leads, I replaced a battery, pulled and bench tested the starter. I cleaned the terminals too. When I checked the leads there was corrosion an inch down the wire in the isulation.
Lesson learned: Start with the cheap stuff first
Old 03-07-2007, 01:56 PM
old4runner's Avatar
it looks like the ground straps just needed to be cleaned up....it seems to be working good now.
Old 03-07-2007, 02:24 PM
surf4runner's Avatar
always a good idea to try the cheap things first
kawazx636
10-06-2021 03:03 PM
Obmi
10-04-2015 11:30 AM
bradahman
10-01-2015 09:24 AM
JPV
09-28-2015 03:15 PM
Rcbc92
09-26-2015 03:00 PM
Quick Reply: Alternator maybe? or battery? or something else
