alternator belt extremely irritating
Old 12-16-2008, 08:12 AM
g_mau18's Avatar
I have tightened my alternator belt 3 times, each time after about a hundred miles it starts squeeling again. Whats up? Did I buy the wrong belt?
Old 12-16-2008, 08:24 AM
rdlsz24's Avatar
Maybe the bolts are working loose? I use a crowbar against the alternator to get my belt really tight.
Rob
Old 12-16-2008, 08:27 AM
g_mau18's Avatar
thats probably the problem, I also use a crowbar to get it super tight so the bolt's gotta be the culprit. I'll go buy one later today.
Old 12-16-2008, 08:35 AM
rdlsz24's Avatar
You could also try some Loc-Tite on the bolt you have.
Rob
Old 12-16-2008, 08:37 AM
g_mau18's Avatar
ok ill try that instead, thanks for the help
Old 12-16-2008, 08:53 AM
BigBluePile's Avatar
on my high quality rebuild altenator the threads stripped out just enough that it wouldn't hold torque on that upper mount. So, I just put a longer bolt in and put a nut on the back side and haven't had a problem since.
shooter86314
01-07-2016 07:05 AM
Zach_trun
11-17-2015 07:56 AM
mbomberz1
10-09-2015 07:17 PM
SCZIG
09-20-2015 09:00 AM
langry345
09-14-2015 03:36 PM
Quick Reply: alternator belt extremely irritating
