Air box?
Old 09-15-2006, 04:24 PM
yelloyota's Avatar
How do you check it?
Jeff
Old 09-15-2006, 04:33 PM
mt_goat's Avatar
Originally Posted by yelloyota
Ok now since I can get it runnin and when I push on the throttle I don't have any but I know its not the cable , its like not havin any throttle or not gettin any gas, but their is gas and the fuel pump is workin, no throttle response it what I am tryin to say ...... yeah thats it.
any ideas?
Jeff
Well it sounds kind of like my truck ran after I accidently ripped the wires out of the AFM. I had a CEL and in would idle fine but as soon as I steped on the gas there was nothing, it didn't die but it didn't go either.
Old 09-15-2006, 07:13 PM
^VooDoo^'s Avatar
Yah, Sounds like AFM bad, Even if the TPS was bad it would trhottle up and you would have to clutch more to get the rpm up,Thats how mine was when
TPS was all bad but the idle sensor and no CEL.
The TPS tells the ECU 2 things, one is your no longer idling and the second that you are trying to excellerate (dump alot of fuel in) or decellerate (Stop fuel , THe AFM Is what Lets the fuelpump continue running and tells the ECU that the engine is flowing such amount of air and to dump the needed amount of fuel, The O2 sensor compensates the AFM.
mussy01
12-13-2016 08:20 PM
delmert
09-30-2015 04:34 PM
94whiterunner
07-12-2015 07:15 PM
crashburnoveride
07-10-2015 06:39 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: Air box?
