adjusting clutch?
Old 09-28-2008, 06:43 PM
sincal's Avatar
adjusting clutch?
Ok i took on the task of replacing my clutch. All went well until i took it for the test drive. My pedal now is really soft. There is not much resistance as there was before. I did not open any lines so i know there isnt air in the lines. Is there something i can adjust or what? If you have any ideas please send them my way. THanks
Old 09-28-2008, 06:53 PM
jason191918's Avatar
Does it drive fine? The clutch could just have a different clamping force/spring rate. My new clutch was waaaaaaaaaaay softer than the one I replaced, but that's just the way it is. If there is a problem, you can't adjust anything, must check fluid/bleed system, but you said you didn't disconnect anything, so this probably isn't the case.
Old 09-28-2008, 06:55 PM
sincal's Avatar
There was no need to disconnect any lines so didnt but i was told by a friend that you have to adjust the spring that goes to the fork. Is that so or no?
Old 09-28-2008, 06:57 PM
I never heard of that.
Old 09-28-2008, 07:00 PM
sincal's Avatar
oh, well ok then..lol he doesnt have a toyota so he could be wrong.
Old 09-28-2008, 07:01 PM
Anyone else have an answer?
Old 09-28-2008, 07:48 PM
toyminator2000's Avatar
The pedal pressure is determined by the spring rate of the pressure plate.
Old 09-28-2008, 07:53 PM
forbiddenera's Avatar
And hydraulic clutches are supposed to be 'self adjusting'.
There is a way to adjust the pedal however, it probably shouldn't be nessicary, but you can check the FSM for instructions.
Old 09-28-2008, 08:00 PM
sincal's Avatar
anybody have any insight to this adjustment?
Old 09-28-2008, 08:03 PM
http://www.ncttora.com/fsm/1993/clutch/2checkand.pdf
This is for a 93.
Pretty sure you are good to go though, like I said before.
Old 09-28-2008, 08:23 PM
sincal's Avatar
I understand the pedal adjustment i was just asking is there one that would ultimately stiffen up the pedal push.
Old 09-28-2008, 08:32 PM
Either a pressure plate with a higher spring rate, or a different pivot point. Either way you would need a different pressure plate. Why do you want it stiffer (stiffer doesn't necessarily mean more clamping force).
Old 09-28-2008, 08:35 PM
sincal's Avatar
Im just so used to the feel of the centerforce clutch being so stiff. This time i went with a differnt clutch and man the difference is A LOT. I just didnt know if it was just the plate or if maybe a adjustment somewhere.
Old 09-28-2008, 08:42 PM
Now that you mention that you had a centerforce, it has to be the pressure plate. Like I said, mine got softer when I changed mine.
Old 09-28-2008, 09:04 PM
sincal's Avatar
lol..yeah i love the centerforce, but funds couldnt produce another..lol so thats what it is huh.. damn was hoping different.
Old 09-28-2008, 09:36 PM
Alex 400's Avatar
I went from stock to a marlin heavy duty clutch and the pedal became softer even though the clutch has more clamping force.
What kind of clutch did you get?
Old 09-28-2008, 09:39 PM
sincal's Avatar
I got a kragen special. Fenco i believe just dont like how it made the pedal feel at all.
Old 09-28-2008, 09:41 PM
Alex 400's Avatar
Well mine has good feel, but it is as smooth as a honda civic. Have you tried bleeding your clutch system? It might have some air in it or something.
Old 09-28-2008, 09:45 PM
sincal's Avatar
Didnt have any air in there before and i didnt break any lines loose when i replaced the clutch so there should be no air still right?
Old 09-28-2008, 09:54 PM
Correct.
Like I said, a clutch with more clamping force can have less pedal effort due to the fulcrum point in the pressure plate.
Quick Reply: adjusting clutch?
