ABS Removal
Old 11-19-2006, 08:27 AM
neoworm0's Avatar
ABS Removal
I am thinking of removing the ABS system from my truck. Hasn't been hooked up in over a year and never worked well anyway. Has anyone done this that can offer any tips or tricks before I dive into this. Thanks in advance
Old 11-19-2006, 11:34 AM
mt_goat's Avatar
Do you mean you want to remove this:
Old 11-19-2006, 11:51 AM
neoworm0's Avatar
Yes. I guess you just ran new lines from the PS pump to the steering gear. Also how did you redo the brake lines. You mentioned in your swap thread something about a line from a non abs truck.
Old 11-19-2006, 12:13 PM
mt_goat's Avatar
You will need to get a highpressure powersteering hose to run from the pump to gear box. For the low pressure powersteering line you can use ATF cooler line.
For the brake line I used a brake line for a non-abs truck.
I covered it some here in post #60 page 3:
https://www.yotatech.com/forums/show...t=82145&page=3
Mike @ ORS may be able to help you with a custom highpressure powersteering hose or maybe one from a non-ABS truck will work.
Old 11-19-2006, 12:17 PM
neoworm0's Avatar
Thanks, I'm going to hit the dealer tomorrow nd take a look at the non abs schematics. Like you said maybe the lines from the non abs truck will bolt right on. Much appreciated.
Did you remove all the electronics as well?
Old 11-19-2006, 12:45 PM
mt_goat's Avatar
I took out the ABS computer because I needed the space under the dash for a URD computer. It was already disconnected from like 7 years ago.
Old 11-25-2006, 08:17 PM
neoworm0's Avatar
Ok well it's not as exciting as an engine swap but in case anyone wanted to do this I documented it in this thread:
http://bb.bc4x4.com/showthread.php?t=103892
Old 11-25-2006, 08:42 PM
Guest
oly884's Avatar
Pull the fuse in the engine fuse box, It's cheap, easy, and it works. That way, if you want it again, just plop the fuse back in.
Old 11-26-2006, 04:18 AM
mt_goat's Avatar
Good write-up, but you linked all your pics to a private album so we can't see them. You should be able to change the album statis to public.
Old 11-26-2006, 09:49 AM
neoworm0's Avatar
Oops. I'll fix that right away. Can someone tell me if you can see the pics now. Thanks.
Old 11-26-2006, 10:41 AM
marko3xl3's Avatar
I can see them Thanks for the write-up. You should submit one to the YT tech section.
Old 11-26-2006, 10:58 AM
mt_goat's Avatar
Yep it works now.
1uzRunner
63
11-10-2018 03:58 PM
choppe777
05-16-2016 08:00 AM
Anthony Lee Mathis
09-15-2015 07:22 AM
gp66
09-07-2015 08:29 AM
Aaron Logan
09-03-2015 08:08 AM
Quick Reply: ABS Removal
