A340H help
Originally Posted by cmscott16
Your problems are the direct result of a freewheeling overrunning clutch in your torque converter. Basically, you no longer have the use of your stator, which sits inbetween your impeller and turbine and provides for torque multiplication in your torque converter. The stator redirects fluid in order to multiply torque during acceleration. It rotates on an overruning clutch that holds the stator stationary during acceleration. If this clutch fails, or your stator breaks, then you will have no acceleration until stall speeds or your lockup comes on. It is not repairable and you will need to purchase a new torque converter.
I hope many read this.
thats the best info ive seen on a torque converter problems yet.
I did eventually discover that my hisitation/lag/lac of acceleration was due to timming issues as a result of the bottom timing crank gear wearing out the drift key from lack of proper torque from the crankbolt.
see "lesson learned" https://www.yotatech.com/forums/f116/lesson-learned-pics-76293/
At this point i have no reason to think there is anything wrong with the trans. Once i get the motor back in (from the rebuild) we will see!
4runner
so ya i have a 1994 4runner that i just got.
when i went on the free way for the first time i was reving at 4000 rpm. i think it was because overdrice was off. but i dont know has this ever happened to you
Hugh_Mann
08-31-2015 04:02 AM
bb80sc
04-12-2006 06:09 AM
AaronW
11-09-2005 05:27 PM
Cebby
07-26-2005 08:37 PM
