95 SR5 V6 Engine Ticking with RPMs
Old 05-16-2015, 10:37 AM
garbageman's Avatar
Hey Yota Tech, back with another question. My engine has been making a clicking noise in sync with the rpms (faster, more frequent ticks with higher rpms, less ticks at idle). I thought it would be a valve lifter or clearance issue, but a search of youtube, I can't find much for a tear down and check procedure. Before I opened her up and took a peek on my own, I thought I'd ask here and see what anyone else might suggest, or recomend.
TL;DR, engine ticking in sync with rpms. Suspect valve troubles on driver side. Any guides, or suggestions?
Old 05-16-2015, 12:22 PM
garbageman's Avatar
Also, I'm pretty sure the previous owner let the oil run low, and blew the head gasket. I find oil, and coolant dried up on the undercarriage when I'm down there. Also, u suspect the brake booster is bad and I've got the tachometer /odo failure. Not sure if anything is related, I doubt it, but just in case.
shooter86314
01-07-2016 07:05 AM
83yotastockR
11
11-10-2015 06:54 AM
smilen724
13
11-08-2015 04:11 PM
beebeeri000
10-02-2015 10:42 PM
sonorn67
09-19-2015 05:39 PM
Quick Reply: 95 SR5 V6 Engine Ticking with RPMs
