95 4runner 3.0 is missing on 3 cylinders?
Old 01-23-2010, 06:43 AM
vw.dubster's Avatar
So I have a 95 4Runner thats missing on cylinders 1, 3, and 4. I verified this by pulling the wires from the cap while at idle, no change in idle when these are removed. There is spark because I can see and hear (and felt lol) when I pulled the wires. So this leads me to beleive no injector pulse? I'm thinking maybe the wire or connectors to those 3 injectors is loose but I can't find it. Anybody seen this before or have any suggestions? I have not done compression test or checked for power to those injectors but I'm guessing this isnt the first time this problem has occurred on these motors....
Old 01-25-2010, 07:35 AM
CappyKD's Avatar
Do the compression check. I had a miss on one cylinder and it turned out to be an exhaust valve that was so tight that it couldn't close leading to 0 compression in that cylinder.
Old 01-25-2010, 10:53 AM
vw.dubster's Avatar
I did the comp check and all three cylinders showed no compression. It looks like the timing belt skipped a tooth on each side, so I'm gonna adjust that first and post results *fingers crossed*
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MMA_Alex
25
04-18-2017 05:07 AM
MTLroadierunner
07-15-2015 12:58 PM
cyclist231
07-07-2015 12:56 PM
Quick Reply: 95 4runner 3.0 is missing on 3 cylinders?
