93 pickup won't start, but pushstart works
Old 11-09-2010, 03:41 PM
dagnisaun's Avatar
Question 93 pickup won't start, but pushstart works
1993 Toyota pickup, RWD, 22re 5spd manual.
The truck won't start the normal way--turning the key in ignition. Push starting still works and then it will drive without problems.
When I turn the key to start (clutch pedal in, obviously), nothing happens. No sounds.
Probably not the battery. Lights/radio/clock etc all work, and I even tried a new battery.
This problem has happened twice before, but both of those times it fixed itself by the next day. This time..it's been several weeks.
I checked all fuses under the hood and on the driver's side, they all look fine. I removed pretty much all the paneling so I can look at the wiring, but I didn't find anything wrong.
Any suggestions/ideas would be greatly appreciated.
Thanks.
Old 11-09-2010, 03:44 PM
xxxtreme22r's Avatar
starter contacts and solenoid, pretty common, extensively talked about on here, probably would have been found in a search. Maybe the relay if your not getting any clicks whatsoever from the starter.
Old 11-09-2010, 04:42 PM
dagnisaun's Avatar
Of course! I should've searched..
One of your other posts reminded me of something, and I'd like to ask you.
The thing I highlighted in red..Is that on a large plastic wire-lookin thing?
There's one hanging by my starter, but I didn't think of it until I saw your post about a starter wire. I'm looking at the service manual, it looks like the thing that attaches to a magnetic switch. I'm going try attaching it somewhere..
But..I'm not getting any clicks anywhere, you said it could be the relay. Hm.
Old 11-09-2010, 04:49 PM
I don't have one of those on my starter, not sure what it's for, but doubt that's the problem.
Old 11-11-2010, 02:36 PM
thefreqofnature's Avatar
If it wont jump start but will push start...
My bet is your starter ground wire fell off.
Crazychris1871
06-27-2016 10:38 AM
Cesarl74
04-23-2016 06:07 PM
newzingo
06-24-2015 01:50 PM
gog1968
06-22-2015 05:55 AM
Corey
06-10-2002 04:23 AM
Quick Reply: 93 pickup won't start, but pushstart works
