93 extended cab driveshaft question
I have a 93 22re 4x4 extended cab DLX. I have replaced the carrier bearing 3 times now. All of them wearing out and becoming sloppy. My question is that Is it possible to make the 2 pc drive shaft into a one pc?
Suspension altercations are
Rear add a leaf
Front cranked up torsion bars
Thanks
Rear add a leaf
Thanks
Well the vibrations are from my carrier bearing. I can move it about 1/2 inch up and down. I get it replaced and its silky smooth then within a short time is bad again. I would like to do away with it all together.
That's what this other guy's problem was, it was eating carrier bearings so he done away with the 2 piece, and still had vibrations. See if your pinion bearing is bad before you spend several hundred dollars on a one piece driveshaft.
The answer:
Yes you can run a 1 piece driveshaft.
is there one that will just bolt on? I don't think so. I know on trucks a one piece can be used if you're using a dual case off a 4Runner, but without that extra length, probably wont work.
Its not expensive to get a custom driveshaft with a flex/cv joint made. Mine cost me about 120 to be sleeved, and a CV joint added on my 4Runner.
Good luck.
Good luck.
Road Bull
10-10-2015 04:55 PM
