93 3VZE high idle
Old 03-25-2006, 01:49 PM
95SASMudRunner's Avatar
93 3VZE high idle
Been having so problems with my engine at a higher idle than i would like, it stays at a perfect 1100-1200 not rought no bouncing, just high, replaced all the typical, pcv, plugs, wires, cap, rotor, fuel filter, as they all needed it... Any other suggestions to get it back down to the factory 800RPMs? thanks
Old 03-25-2006, 02:06 PM
ChickenLover's Avatar
Just turn it down by adjusting the idle screw on the T-body.
Old 03-25-2006, 04:02 PM
Elton's Avatar
not to be rude but use the search button next time you will find your answer
Old 03-25-2006, 04:57 PM
regularguy412's Avatar
Turn the idle screw back down -- check your base engine timing - the check the idle again. The TPS out of adjustment can affect idle, as well.
Mike in AR
tomczaksdiesel
07-26-2015 10:35 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 93 3VZE high idle
