92 toyota pickup won't start when hot
Old 12-03-2011, 08:20 AM
ohale's Avatar
trying to fix a 92 toyota pickup. when you drive it and it gets warm it will not start. after i sits for abour 45 minutes it will crank up. the motor turns over very well. if you use starting fluid it will fire up after a couple of trys. i know it must be a fuel issue, i've replaced the core relay and fuel filter. any suggestions? any help appreciated.
Old 12-03-2011, 09:12 AM
sharpy46's Avatar
pretty common issue that i, myself have gone thru. check the cold start inj time switch....and the cold start injector. also follow the fuel pump test procedure outlined here....just do a lil searching.
Old 12-03-2011, 09:22 AM
sharpy46's Avatar
check this out
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
6th Gear
19
12-10-2019 07:31 AM
Crazychris1871
06-27-2016 10:38 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
newzingo
06-24-2015 01:50 PM
94hiluxZE
06-22-2015 10:42 AM
Quick Reply: 92 toyota pickup won't start when hot
