92 Toyota 3.0 pickup stalls after start
Old 05-21-2014, 03:42 PM
JRL421's Avatar
I am having trouble with getting my vehicle on the road. i recently spark plug wires,distributor cap, and replaced the mass air flow sensor, which i thought was the cause of my problem.
It ran good while it did and started to run rougher each time i tried starting. which was about three times. i noticed the smell of gas as if the engine was flooded after the initial start up and stall. Any suggestions would help.
Old 05-22-2014, 02:48 AM
fangz's Avatar
take the air inlet manifold off and check the fuel rail for leaks , while your in there check your injectors , a injector rebuild kit is ˟˟˟˟ all and easy as fcuk to do .
there is also a tiny fuel filter in your cold start injector that alot of people dont know about , take the cold start injector out and have a look where the fuel gos in you will see the filter , most of the time they are blocked with crap or deteriorated .
if it is deteriorated then there is a good chance the filters in your injectors are blocked with crap .
good luck
JF9243176
10-08-2017 04:21 AM
Alex Bessinger
06-28-2015 10:05 AM
bprice0077
06-25-2015 07:36 AM
JF9243176
06-24-2015 04:53 AM
nyk08trx
06-18-2015 09:01 PM
Quick Reply: 92 Toyota 3.0 pickup stalls after start
