92 pick up FULL TUNE UP NEEDS?
Old 10-18-2015, 01:08 AM
davidsalas's Avatar
Just bought a 92 Toyota pick up 5spd 2.4 L 4x4... Looking to do a full tune up, want to make sure I'm running smooth. What should I replace ??? Thanks guys
Old 10-18-2015, 02:15 AM
anndel's Avatar
Plugs, wires, distributor cap, rotor, air filter, Chevron or Red Line or Gumout fuel injector cleaner, maybe drain and replace coolant, oil and filter, check brake fluid, drain and replace front and rear diff gear oil, manual tranny fluid, transfer fluid, grease spider and u joints, check cv boots, check brakes, maybe tires and spare.
Old 10-18-2015, 02:16 AM
anndel's Avatar
Don't forget to check the timing chain if its rubbing on the timing chain cover
Old 10-18-2015, 02:19 AM
bipolarandproud's Avatar
Check/Adjust valves.
Old 10-18-2015, 07:25 AM
Staff
Terrys87's Avatar
Clean Intake and check if vacuum lines are in great shape and routed correctly.
Matt89toyota
06-27-2023 08:00 AM
ZGjethro
06-07-2017 11:04 PM
moparbay
10-06-2015 09:24 AM
mluz013
09-29-2015 05:53 PM
Quick Reply: 92 pick up FULL TUNE UP NEEDS?
