92 4runner lost power
Old 02-12-2012, 05:42 PM
93YotaMonster's Avatar
hey guy's im having a problem with my moms 92 4runner with the 3.slow she bout it as a lil beater to get to an from work but all of a sudden it has no power. i Know the 3.slows are not power houses but they should be able to do over 45. the guy she got it from had just done the timing belt. he said he put everything back right. at idle it runs smooth no shacking or anything but you get it on the road and its weak as hell.
Old 02-12-2012, 06:07 PM
rworegon's Avatar
Did it have proper power/get above 45 mph when she first drove it?
Check for loose or cracked vacuum hoses and loose ground wires. Sounds like the timing is off to me.
Page EG2-26:
http://www.ncttora.com/fsm/1990-1995...eme/tuneup.pdf
Crank/Cam Timing EG2-42 thru 44:
http://www.ncttora.com/fsm/1990-1995...e/timingbe.pdf
Old 02-12-2012, 06:31 PM
yeah it wasn't bad, but the power loss is not always there it comes and goes. wouldn't it have a ruff idle if it had vacum leak or bad plug wire?
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
jon.r
07-11-2015 03:34 PM
skoti89
07-08-2015 12:05 AM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: 92 4runner lost power
