92 4runner 4x4 3.9Liter Blown Transmission
Old 05-14-2014, 06:53 PM
92-4runner4x4's Avatar
Hey Guys, So i'm gonna be swapping my transmission I was wondering what size Sockets that i will need, And another question will be my rear main seal is that hard to change could anyone explain to me how to Change that, And how to know if i need a new rear main seal?
Old 05-15-2014, 11:55 AM
crazytexan's Avatar
Rear main obviously will have oil leaking all around it and bell housing. Area. It's easy to change when the trans is out, BUT it sits in an aluminum housing (you'll see it when u get there) and it's the housing that is also not only bolted to engine block but also through the oil pan lip. Removing it will most likely disturb the oil pan gasket and create another nasty leak that's a huge PITA to change w.o pulling the engine.
Biggest socket is mby a 19mm for rotating the engine to get tq converter bolts, or use a prybar to rotate it. Standard tools will work, nothing special needed.
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
MTLroadierunner
07-06-2015 12:17 PM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 92 4runner 4x4 3.9Liter Blown Transmission
