91 yota 4runner help
Old Dec 17, 2007 | 06:05 PM
4runnerguy's Avatar
how do u know if the EGR is workin
Old Dec 17, 2007 | 06:10 PM
4runnerguy's Avatar
some one must know
Old Dec 17, 2007 | 07:12 PM
Targetnut's Avatar
Use a vacuum pump and pump up the valve with about 10" vacuum while the engine is idling. The engine should run very rough or stall. then connect a vacuum guage to the hose for the EGR valve and goose the throttle You should see the vacuum come up just as the throttle is opened
If this all works, the the EGR should work.
Old Dec 18, 2007 | 04:45 AM
4runnerguy's Avatar
is there another way. and i dont a a vacuum guage and can i use an vacuum pump that i all ready have under the hood
Old Dec 18, 2007 | 09:38 AM
4runnerguy's Avatar
eny one
Old Dec 18, 2007 | 10:32 AM
4runnerguy's Avatar
and i have this thing that once in a wile the rpm drops and comes right back up its a 3.0
Old Dec 18, 2007 | 04:58 PM
Targetnut's Avatar
If that is the symptom you are trying to diagnose, It is not likely to be related to the EGR function. You could disconnect the EGR and drive around to see if the symptom goes away. And it probably won't.
Old Dec 18, 2007 | 06:48 PM
4runnerguy's Avatar
do u know waht it could be
Old Dec 18, 2007 | 06:51 PM
to4menon4u's Avatar
it might be a dead spot or dirty spot in the tps
icentropy
Sep 16, 2020 02:47 PM
Regency
20
Jan 3, 2020 07:43 PM
tobylab
Jan 18, 2016 07:06 PM
BeMiceElf
Oct 10, 2015 09:40 PM
tobylab
Jul 12, 2015 12:53 PM
