91 yota 4runner help
Use a vacuum pump and pump up the valve with about 10" vacuum while the engine is idling. The engine should run very rough or stall. then connect a vacuum guage to the hose for the EGR valve and goose the throttle You should see the vacuum come up just as the throttle is opened
If this all works, the the EGR should work.
If that is the symptom you are trying to diagnose, It is not likely to be related to the EGR function. You could disconnect the EGR and drive around to see if the symptom goes away. And it probably won't.
Regency
20
Jan 3, 2020 07:43 PM
BeMiceElf
Oct 10, 2015 09:40 PM
