90 vs 94 alt on 3.0
Old 04-10-2008, 11:26 AM
4x4phil's Avatar
90 vs 94 alt on 3.0
I have a 90 3.0 and I bought a bunch of used parts for real cheap and they came from a 94 3.0
my alt went bad, I have the one from the 94 but it has a diffrent plug, but I have the wiring harness so i could spilce it in
is this ok to do and has any one done this?
any write ups?
I dont want to have to buy a new one when I have a good used one laying around
Old 04-10-2008, 12:54 PM
anotherjeff's Avatar
What went bad with original alt? If it's just the brushes (typical), replace them.
Alternatively, swap the rectifiers (with plugs) between alts. It's an easy task.
Old 04-10-2008, 01:51 PM
4x4phil's Avatar
what are the rectifers?
is that just the pug in the back of the alt?
I was thinking of just swapping the plug and butt conect together.
I think this will work out just fine, but I want someone elses opion
Old 04-10-2008, 01:56 PM
TOYOTA 1's Avatar
i think what he is saying is, swap out your plug for the other. they come apart! and you can put your original wires in the new plug!
Old 04-10-2008, 01:59 PM
4x4phil's Avatar
oh.......nice!!!!! very nice!!!!!
that should work, if not I guess spice and dice!
Old 04-10-2008, 02:03 PM
TOYOTA 1's Avatar
ya lol, that would probably work to!
Old 04-10-2008, 02:20 PM
GVOLCRunner's Avatar
NO SPLICE AND DICE needed.
I did the exact same thing, had my alt go out on my 90 v6, went to a slavage yard and got one off a 94. You just take apart the plug. Take the orginal one off of your old alt and put it on the new. Works perfect.
Old 04-10-2008, 03:27 PM
4x4phil's Avatar
I feel so much better now!!
thanks!!!!
Old 04-10-2008, 05:35 PM
Oops! I said "rectifier", but I meant "voltage regulator"! The plug is attached to the regulator.
Old 04-10-2008, 05:57 PM
Noltz's Avatar
Is the output of the 3.4 alternator any better than the 3.0's?
Old 04-10-2008, 09:26 PM
Matt16's Avatar
Fix the old one. Its probably the brushes.
Old 04-10-2008, 09:49 PM
TOYOTA 1's Avatar
thanks!!!!
gota love yt. buncha yota nerds
Old 04-14-2008, 02:51 PM
4x4phil's Avatar
I fixed it by swapping out the plug, i will have the old one repaired now that it is out.
Thanks for everyones help!!!
now if I can just pull that darn PCV valve with out pulling the intake....
91yotapup
3.4 Swaps
03-05-2019 10:41 AM
scott90
10-04-2015 09:21 AM
93RedKrawler
09-29-2015 02:50 PM
mtrdrms
09-26-2015 07:12 AM
sonorn67
09-19-2015 05:39 PM
Quick Reply: 90 vs 94 alt on 3.0
