90 4runner blowing turn signal fuses
Old 04-10-2008, 02:38 PM
wastedracing's Avatar
so the other day i was driving the 90 4runner and went to change lanes and turned on the signal it flashed then all of a sudden stopped i pulled over looked at fuse sure enough it was blown then i put a new one in and i turn the signal on again and about 30 seconds into flashing it blows again and i repeat same thing obviously i have a short somewhere but where?
thanks for any and all help
Old 04-10-2008, 02:54 PM
machabees's Avatar
start by replacing the bulbs. sometimes the filaments get loose when they are old and this causes the fuse to blow.
Old 04-10-2008, 05:01 PM
bulbs all look good are the rear backup lights on the same circuit?
Old 04-10-2008, 05:26 PM
steanson's Avatar
just a thought...check this thread out...I had problems last year with my signals blowing fuses...
https://www.yotatech.com/forums/f131...inking-116763/
Old 04-10-2008, 09:32 PM
so any ideas where i should look now when i put in a fuse the hazards dont work at all should i look there first? also the horn doesnt work? is all this on the same circuit?
Old 04-10-2008, 10:01 PM
Dare44's Avatar
screw it and hard wire everything u dont need fuses no dont do that jk u really do hope u have fun finding those electrical gremlins
Old 04-11-2008, 02:55 PM
so i popped the hood and the horn/hazard fuse was blown also so i put a new fuse in both locations and now it seems to be working fine weird
Old 04-11-2008, 03:26 PM
steanson's Avatar
if it intermittently blows fuses in the future...reread that link I sent earlier. Hopefully this was just a fluke, but mine was 2 loose ground wires, so they worked for a while, then *poof*....another fuse. Hopefully you squished the gremlin.
06-01-2021 01:51 PM
MTLroadierunner
07-15-2015 12:58 PM
Kalihi,HI
07-09-2015 04:29 PM
Suprarossa
07-06-2015 05:21 AM
karbin
07-05-2015 11:37 PM
Quick Reply: 90 4runner blowing turn signal fuses
