90 22re swap into 89 toyota truck questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-22-2006, 04:38 PM   #1 (permalink)
Alright, recieved a 1989 yota pickup for free...good price huh. Body is solid, bed, frame, etc all solid which was a huge surprise seems how my 88 had major rot. Anyways, the guy who owned it, never marked any wires or vaccum hoses when taking stuff apart, so i'm having a good time trying to figure where stuff goes. The main problem, is the motor he bought for a replacement is a 1990 22re and so far all of the connecter plugs haven't matched up. Luckily he had some of the stuff from the old motor like the fuel rail with injectors and some of the sensors. Does anyone know what major problems I am going to run into trying to retro the 90 22re into my 89? Does anyone have a good wiring diagram and vaccum hose diagram. I have a haynes but it is worthless. Another problem I have noticed is that the emissions seem to be different setups. Now what I thought would be a quick plug and play install has turned into a headache.....any help is appreciated!
YOTAKIMMER is offline
Old 10-22-2006, 05:03 PM   #2 (permalink)
First step is get the FSM both volumes, they're expensive compared to haynes or chilton but worth every penny. Also do you have digital camera? This project could take awhile but hey it was free so if you ever get ready to sell it look at all the profit. Also search all the forums you can there is a wealth of knowledge out there. Good luck and I'll help you all I can.
bodo is offline
Old 10-22-2006, 05:51 PM   #3 (permalink)
Thanks bodo, it should be an interesting swap. I just ordered a factory manual on cd, but i'm going to wing it in the mean time. I'll work on it some more tomorrow and let you know what I run into. Thanks again!
Old 10-22-2006, 06:20 PM   #4 (permalink)
Yeah the cd's are good but I hate taking a laptop in the shop to work on something greasy fingers and all. I'd rather have a book sitting there it's just easier for me. The long block is the same form 85' efi to 95'. Do you have the old motor? What condition is the engine bay in, I mean is the intake just hanging in there or is everything pulled out? When I built the my stroker I had it on one stand and pulled my original motor and put it another and swapped all the parts over. Now hooking things up that weren't labeled is another thing.
bodo is offline
Old 10-23-2006, 07:33 PM   #5 (permalink)
The newer block is bolted up to the tranny (noticed the bolts from the trans to transfercase are missing) and the lower part of the intake manifold and the fuel rail from the old engine is mounted. I switched all but one of the sensors with the ones from the original engine. Now i'm to the point of running the harness and then mounting the upper intake and hooking up vaccum hoses. I'll take a pic of one of the wires that I have no idea where it goes..lol. Gonna work on it for a few hours tomorrow. None of the stuff was labeled when the guy took it apart so I have to figure out the vaccum and wires from square one.
Also, how do you tell which plug goes to which injector? I thought they would have made them with some markings or something to identify what goes to what, but they didn't.
Old 10-23-2006, 08:19 PM   #6 (permalink)
I'll PM you I hate typing.
bodo is offline
Old 10-23-2006, 09:00 PM   #7 (permalink)
millertime_t1's Avatar
I just finished up doing that exact thing --- 90-89 22re everything was plug and play -- it all fit and it all matched
millertime_t1 is offline
Old 10-23-2006, 09:02 PM   #8 (permalink)
Oops -- I did have to swap the knock sensor the connectors were bassackwards designs
Old 10-23-2006, 10:53 PM   #9 (permalink)
toy2005's Avatar
Send a message via AIM to toy2005
Just think though if you went carbureted you wouldnt of have to do all that. I know the Haynes book is well descriptive of where everything goes, if you need help.
__________________
ToY2005. My yota consists of the stock 22r block with brand new offenhauser downdraft intake custom for weber 38, new radiator, efi pro cam for LC engineering 280 duration 440 lift, with valve lash at 8,12. I also have 37.5 intake and 45.5 exhaust valves with pro flow headers. The is also a dual row timing chain set with medal guides and a adjustable cam gear. My fuel flow is controlled by a Malory high volume low psi fuel pump series 70. Stock ignition coil, distributor and NGK iridium plugs.
toy2005 is offline
Old 10-24-2006, 02:34 AM   #10 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
I didnt think the changes in the 22re happened until 92, IIRC 89-90 should be plug and play.
Good luck with it all...
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 10-24-2006, 08:07 AM   #11 (permalink)
I no nothing is matching up, so maybe the engine came from a 92. The guy who bought the motor told me 90, but you guys have more knowledge about this stuff than he does.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
89-95 truck door swap? standardbyker88 86-95 Trucks & 4Runners 1 03-16-2007 10:56 PM
22re swap 87 22re in a 90 pickup yotaboy66 86-95 Trucks & 4Runners 2 12-14-2006 05:05 PM
Axle/Gear Swap Help: Will a '94 Auto-V6 4x4 axle swap into my '90 22RE-5spd 4x4? Justin311 86-95 Trucks & 4Runners 15 04-15-2006 12:18 AM
Solid Axle Swap (SAS) On An '89 Toyota Truck Robinhood150 Off Road Enhancements 0 01-07-2006 07:27 PM
2009 InternetBrands, Inc.
