89 automatic transmission replacement ???
Old 02-10-2011, 09:21 AM
Speach's Avatar
My truck is an 89 4runner with an automatic transmission. It has been giving me problems by slipping and what not. Any tips or tricks or typical difficult issues on how to remove and replace it. Also my timing chain rattles a bit so I would like to replace that at the same time. Any tips on that too?
Thanks
Old 04-25-2011, 04:58 PM
david joseph's Avatar
EASY. dont worry about it. buy a haynes manual and follow it, cant go wrong.
Old 04-25-2011, 06:55 PM
BigSwole's Avatar
U can if you buy the haynes. Its the most vague p.o.s. I ever bought. Save your money and use the search button. Save you time and money.
You can thank me later.
Lol really its that bad
Old 04-25-2011, 07:08 PM
The Haynes manual has vehicle specific information, you need a little common knowledge and common sence. Any mechanically inclined person should be able to figure out a transmission swap on one of these relativly simple trucks. I wasnt a mechanic when I managed it with just the manual. Also, Dont forget to use drift pins when pulling and attaching the bell-housing, makes things a hell of a lot easier!!
Old 04-25-2011, 07:12 PM
MID SIZED BOSS's Avatar
Not trying to stir things up dude but IMO anything other than manufacturer manuals are difficult to use if you are new to projects of this size. Especially considering that a Haynes manual does not have a section on swapping out a auto for a manual trans. It does however have the info you need for a timing chain guide replacement.
Now with that said if you combine a Haynes with this website you have a solid source of information.
Best of luck you can do it just do it right.
Old 04-25-2011, 07:14 PM
Sponsor
Tofer's Avatar
haynes manual works great as a coaster or something to stabilize a rickity table..... otherwise www.ncttora.com/fsm is your friend.
touche!
smthwsn357
12-04-2023 02:08 AM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 89 automatic transmission replacement ???
