89 automatic body lift question
Old Oct 12, 2006 | 12:17 PM
89red4x4yota's Avatar
ok i'm at school and i went home for the weekend and saw that there was a ad in my local classifieds saying the is a summit racing 3 inch body lift for an 89-95 toyota pickups. its new in box guy sold the truck and never put it in, its $50 for the complete kit. my question is he said it was for a manuel transmission truck, i have a 1989 Automatic. will it be the same kit, all i should need is the transfer case extension? right? anything else? the transfer case extension on 4 crawler is $55 or something, do i need anything else from 4crawler. should i buy it?
Old Oct 12, 2006 | 12:34 PM
waskillywabbit's Avatar
Look it up on Summit and see what their website says.
http://www.wabfab.org/products/bl/1stgenbodylift.htm
Old Oct 12, 2006 | 03:18 PM
their website says it comes with everything neccesary i just wanted to know if the only thing different with the two body lifts is the transmission? the trucks are the same right?
Old Oct 12, 2006 | 04:02 PM
mt_goat's Avatar
3 inches is a lot of BL, are you sure you want that much? You will need modifications to the auto shifter linkage, steering, etc... Check out 4crawler's info: http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
Old Oct 12, 2006 | 07:23 PM
faubrunner64's Avatar
i did a 3 inch bl with the drivetrain lift to and it is an adventure but the results are realy satisfyin.... more underbelly ground clearance!
Old Oct 13, 2006 | 07:24 AM
runner 64 did you get your body lift from roger? whatd you have to do/extend to your truck?
Old Oct 13, 2006 | 09:53 AM
yes i did get it from rodger! the lift was easy i put it in while my engine was out so putting th body lift and drivetrain lift was very easy! i put on a 3 inch if you decide to go this rout disconect the xfer case linkage and the wireing harnase that runs the battery cables needs to be taken off its mount but thats it for a 3 inch! then youll want a low profile cross member form budbuilt
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
