89 4x4 manual trans wiring ?
Old 05-08-2011, 12:49 PM
rusty1891's Avatar
so on the passenger side of the the truck there is a sensor or something hooked up to the tranny. my wires came out of the plug and i need to know which 1 goes on top.
Old 05-08-2011, 12:54 PM
justin_4runner's Avatar
is it a 2 wire plug towards the front? if so it really doesn't matter its the reverse light switch.
Old 05-08-2011, 03:19 PM
rusty1891's Avatar
it is a 2 wire plug and if i remember correctly it is towards the rear.
Old 05-08-2011, 03:22 PM
NicCantDecide's Avatar
It's just the reverse light switch, there's no other electronics on the whole transmission.
Polarity doesn't matter on switches so you can hook it up one way or the other.
Old 05-08-2011, 03:30 PM
Mr.Utah's Avatar
On my w-56, there are two wires. The one on the drivers side is the reverse light, it goes over the top of the transmission and plugs into the harness. So when it came out on mine, it was drooping down on the passenger side. After plugging it back in, the reverse lights worked. There is also a wire on the passenger side, I'm not sure if its a fluid level or a temp gauge.
Old 05-08-2011, 03:46 PM
rusty1891's Avatar
do you know which wire goes on top on that plug coming from the harness th green or the white one?
Old 05-08-2011, 03:59 PM
rusty u can put the green or white on top or on bottom it does not matter,
Old 05-08-2011, 04:16 PM
rusty1891's Avatar
alright i'll hook it up tomorrow after work and let you all know how it goes
Old 05-08-2011, 05:01 PM
Mr.Utah's Avatar
The reverse light is next to the fill bolt, wraps over the transmission and plugs into the harness with one RED wire and one RED/WHITE striped wire.
The other wire on the transmission is black on the passenger side, much higher and further back. I believe this is the 4x4 indication wire.
hope this helps
Old 05-09-2011, 08:15 PM
rusty1891's Avatar
thaks it helped alot the wires goto the 4wd indicator got it all hooked up and it's good to go thanks for everyones input
Old 05-11-2011, 08:39 PM
IDRUNNER's Avatar
Thanks for answering my question b/4 I posted. My problem is that the tranny was swapped and the back up light connection is too short and they don't match. The "rear" connection only has a connector on the harness the connector from up top is a bare wire.
MO transplant
04-23-2023 11:58 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
smiley52
07-11-2015 05:16 AM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 89 4x4 manual trans wiring ?
