87 4runner ZUK mod question
Ok, i hav customary sagging rear end common on most 1st gen runners. What springs do you guys recommend for doing the ZUK mod? I know i have read where 12 to 13 inches is generally what people are using, but as far as brand and where you get them, any suggestions?
Here is some info from the web page of the man who came up with this awesome idea:
General info:
http://gearinstalls.com/dc.htm
Alternate way to install:
http://gearinstalls.com/coilnoweld.htm
Where to get the ones he recommends:
http://gearinstalls.com/coilinfo.htm
Hope that helps
General info:
Hope that helps
I just did the no cut ZUK mod... check out my build thread where I posted the link to the mod write up.
https://www.yotatech.com/forums/f199...-build-289215/
ZUK himself did the work on my 4Runner about 7 or 8 years ago while I had it over at his shop getting a Detroit locker install. I still have the same setup and it works great! I have the 12", 120lb Black Magic Springs
And this setup does not produce too much rake. No need to crank torsion bar. This is on stock 1986 manual tranny 4 Runner.
TURBOrunnerNM
07-22-2015 11:01 AM
icentropy
07-11-2015 07:21 AM
