'87 4runner gas mileage drop..need help
Old Jun 22, 2008 | 09:14 PM
kipres's Avatar
I have a gas mileage problem. I have a 1987 toyota 4runner sr5 turbo minus the turbo, turbo is currently off. Two weeks ago I was getting 14mpg now Im getting 10mpg. I put a new muffler on, new plugs, wires, cap and rotor, air filter and topped off all fluids. What would make my mileage drop?
Old Jun 22, 2008 | 10:42 PM
24Runna's Avatar
Reset ECU.
Bad O2 sensor, bad gas, driving habits maybe.
Old Jun 23, 2008 | 10:24 AM
kipres's Avatar
how do i reset the ecu and how do i check the o2 sensor
Old Jun 23, 2008 | 08:56 PM
kipres's Avatar
ok so i did some looking today and i found the problem my knock sensor was broken. this little plastic thing cost 169.89,any idea where i can get one for cheap? besides a junk yard
Old Jun 23, 2008 | 09:33 PM
24Runna's Avatar
Try looking in the classifieds for people parting out. I tried looking at some sites, but they were more expensive.
Old Jun 23, 2008 | 09:35 PM
NorCrawler's Avatar
why would you take the turbo off?
what was your MPG with the turbo?
Old Jun 23, 2008 | 09:48 PM
corax's Avatar
there's a Pick A Part right up in San Berardino. $2 to get in and they've never checked my pants pockets yet . . .
knock sensors all pretty much work the same, as long as the connector plugs in and the part that screws into the block is the same it should work. I would imagine most Toyota sensors are the same
pickapart.org
Old Jun 24, 2008 | 08:45 PM
kipres's Avatar
thanks. i went and got the sensor today and put it in. runs better now, but the a/t temp and charge still comes on at 30mph . any ideas? also how do i reset the ecu? the turbo was off when i baught the runner. i have everything for the turbo but the intake from the turbo to the intake manifold, and the junk yards around here dont have any turbo toyotas
Old Jun 24, 2008 | 08:57 PM
corax's Avatar
reset ECU - disconnect negative battery terminal - smoke a cig, drink a beer or just wait 5 minutes and reconnect
charge light - you'll need to check voltage, it may be over or undercharging, last year my runner was overcharging whenever I spun it over 5500rpm regarless of vehicle speed - I think Autozone will test it for free if you take it off, but they might be able to test it on the car too, Sears could also test the charging system, but may charge, in either case it would be best to call first
A/T temp - check the trans fluid, low fluid will heat up faster - may be caused by weird voltage from the alternator, but I'm not really sure - address the charging problem first, but keep an eye on the A/T Temp to be safe
Old Jun 24, 2008 | 09:09 PM
kipres's Avatar
thanks again! auto zone did the test and everything was good ill check the trans fluid while i smoke a cig and drink a beer during the reset of the ecu
Old Jun 24, 2008 | 09:54 PM
kipres's Avatar
I checked all fluids again and reset the ECU waited 15-20 minutes. Then i drove a quarter mile and lights came back on. I wiggled some wires and stuff around while still running then turned off for 2 minutes started it back up and lights were off again like always. but this time they stayed off completely all the way home. I will see what happens tomorrow, will update you then. Thankyou
Old Jun 25, 2008 | 11:05 PM
corax's Avatar
if there is a wire problem, it will be in the area you were just moving. most problems will occur where there is hard bend in the harness. If you carefully strip the plastic coating off the outside of that bunch and look closely, you might find a stretched wire or a break - hold one end of the wire and gently pull down the length of it, you will feel where the wire gets "thin" inside the insulation
Old Jul 5, 2008 | 11:14 PM
kipres's Avatar
ok so the lights have been coming on again a\t oil temp light, charge light, and brake light, so i did a diagnostic test on it #11 came up which is throttle position sensor, where is this located and can i clean it?
Old Jul 6, 2008 | 12:06 AM
CC_yota's Avatar
It looks like the FSM has it placed on the side of the TB next to the intake. Mind you that's on a N/A 93 22RE. You check the TPS with an ohmmeter per the FSM instructions and specs.
Old Jul 10, 2008 | 06:07 PM
kipres's Avatar
thanks for the info, but now there is anew issue. the truck runs fine, the battery is staying charged, and the alt test good, but theres no amps being read on the 60 amp alt. any thoughts?
Old Jul 11, 2008 | 04:54 AM
abecedarian's Avatar
do you mean no amperage showing on the dash? maybe a fuse has excused itself from operating? or possibly something in the wiring between the fuse block under the hood and the dash.
Old Jul 22, 2008 | 10:53 PM
kipres's Avatar
autozone hooked it to a tester while in the truck and running and it read full charge but no amps (alternator)
Charecter1
Nov 6, 2023 10:08 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Kluch8651
Jul 9, 2015 10:39 AM
skoti89
Jul 6, 2015 07:45 PM
Jnkml
Jul 6, 2015 01:20 PM
