86 wiring
Old 03-26-2012, 12:35 PM
brock77's Avatar
86 wiring
recently had a box drop out from under my dash with wires conected to it.one of these wires was a coil wire that would ark when it touched the steering colum and had now burnt off...truck still runs..just wondering what this wire is and where the box should be mounted thanks brock...
[IMG][/IMG]
[IMG][/IMG]
[IMG
Old 03-26-2012, 01:33 PM
BMcEL's Avatar
Gonna need at least a picture.
Old 03-26-2012, 02:41 PM
brock77's Avatar
pictures added, in the second pic u can see the coil wire and the cone were it used to go before it burned
Old 03-26-2012, 02:43 PM
Staff
Terrys87's Avatar
That looks similar to what was in my 86 runner. I removed mine. I think it is to Cruise Control.Your truck have Cruise?
Old 03-26-2012, 02:51 PM
brock77's Avatar
not sure ill go check ,but u removed what../ the coil wire
Old 03-26-2012, 03:04 PM
Bassmastry101's Avatar
The coil wire?
The box and connectors and wiring all look after market to me. Maybe someone put a gps tracking device thing in your truck!!! Or it could just be an aftermarket alarm system with chopped up wiring.
Old 03-26-2012, 03:07 PM
brock77's Avatar
Originally Posted by Bassmastry101
The coil wire?
would better pics help i can see if can get better ones
[IMG][/IMG]
Old 03-26-2012, 03:41 PM
RAD4Runner's Avatar
Black box in original post (OP?) looks like the housing for that annoying seat bealt & engine on buzzer.
Yes, the red wire looks aftermarket. The white plastic is half of an inline fuse housing. The other half that's missing would have been over that red wire with the spring. It would mate with the first. The spring compresses the fuse to make contact with the other side. I have an FSM for 1986 4Runner. Pls PM me so I can send you a pdf.
Higher resoluton pics would really help.
Regards from new a member,
Old 03-26-2012, 09:20 PM
RAD4Runner's Avatar
Hi Brock77,
I sent you link to 1988 FSM and a link to download actual scans from my 1986 FSM schematics.
"...Would ark when it touched the steering column" means section with with the exposed spring is the positive side (Steering column is ground). It is probably a tap from circuit encircled in red here. If everything's working right with that fuse missing, I would simply remove it.
To be safe:
1) Verify what that red wire is supposed to provide power to. Trace the section with white fuse housing. It is probably just floating- OR it will lead you to what it supplies power to.
2) Trace section with exposed spring back to where it connects to the circuit, and disconnect it.
Best of luck!
Old 03-27-2012, 03:28 AM
Hey RAD, you think I could get in on this 86 FSM scan? Been looking for an 86 specific one for a while.
Old 03-27-2012, 03:39 AM
Utah4Runner86's Avatar
What he said. I'd be happy to kick down for the cost of a thumb drive and a postage stamp!
Old 03-27-2012, 06:51 AM
slacker's Avatar
looks like a remote car starter box ..
Old 03-27-2012, 06:56 AM
Do you think you can get a close up of that wire connection to the box? It doesn't look like a Toyota connection from the picture.
Old 03-30-2012, 08:15 PM
brock77's Avatar
sorry fellas just got off of work im going to look into it tommorrow ...but would i suffer any great consiquences if i disconected it.....
Old 03-31-2012, 07:32 AM
85TurboRunner's Avatar
Looks like somebody put and alarm or something on it. Just start removing wires. That thing is worthless and obviously causing problems.
Start following wires from that box and wherever they connect into your factory harness unhook them.
You'll probably find a few of these guys in there.
Old 03-31-2012, 10:52 AM
brock77's Avatar
turns out it was for the cruise controll ...
Old 04-02-2012, 06:54 AM
JoeT's Avatar
Yeah, I had a similar situation with an aftermarket cruise control. You probably also still have some parts of it under the hood (mechanical actuator attached to throttle linkage, speed sensor, etc.). I ripped all that non-functioning hardware out as well...
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
ToyoToler
08-08-2015 08:43 AM
Daneums
07-28-2015 11:57 AM
TDonkey
07-26-2015 10:14 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: 86 wiring
