86 toyota 4 runner
86 toyota 4 runner
my 86 4 runner is ideling rough and blue smoke is coming out of the exuast the code said o2 sensor or computer replaced both still the same its like its gettting to much fule please healp.
This is quite possible. The extent of the rebuild will depend on a couple of symptoms. When does it smoke? Consistently or for only a short time of driving after start up? And, have you pulled the plugs and PCV to check their condition? The plug/s may be fouled and the PCV valve may be soaked with oil.
Code 11 for the main relay or ingition circuits = loss of power supply to ECU.
Check your code again.......unless you're having that problem, too?
Leaving the cap off wouldn't hurt anything unless your motor oil dumped all over the motor and it ran real low. It would run badly, though.
10k miles ago? Was the motor a rebuild, and did you run the engine through a proper break in procedure to seat the rings? Or was it a used motor?
Right. I suppose it depends on if the code is a one digit or a two digit code 11. A one digit code 11 would make more sense.....that little detaill escaped me.
However, the TPS would have nothing to do with burning oil. So, you're sure the color of the exhaust is blue? I ask because a TPS problem would cause the motor to run rich, but the exhaust would be more of a blackish color (even a lighter blackish) and smell more like fuel and not oil.
Also, did you check the PCV valve and plugs, yet? If you're burning oil, you should have signs of blow-by and/or fouling plugs.
I bet you're just running rich. I'm wrong if you find blow-by....and oh well, I'm wrong. BUT! Just because you replaced the TPS doesn't mean you've addressed the circuit. In other words, you may have an issue with the wiring which you can test with a voltage meter at the ECU....making sure the signal is actually getting there.
Refer to page EG1-261 where it begins at IDL-E2:
http://personal.utulsa.edu/~nathan-b...ne/44engin.pdf
Run the TPS test at that location as you normally would at the TPS itself. However, you only need to check the idle setting....IDL-E2. The rest, disregard for now.
Incidentally, did you test the original TPS before you replaced it?
6th Gear
19
12-10-2019 07:31 AM
JaredL
06-16-2015 04:47 PM
