80 AMP Fuse
Old 03-14-2007, 08:25 PM
old4runner's Avatar
Question 80 AMP Fuse
I blew the 80 amp fuse in the engine compartment, the hanes manual is calling it a fusable link, anyway i figured out that the fuse is screwed to wires in the fuse box and is also attached to a plastic piece that looks like it clips in and i can't figure out how the plasic piece "unclips." I did a search and figured out that i'm not the only one who has had to do this but no one says how you get the plastic piece to come out....does anyone know a trick to getting that thing out???
Old 03-14-2007, 08:35 PM
^VooDoo^'s Avatar
On the 92 the clip is on the top and a flat head screwdriver will undo it, But, It slides downward, Should move really easy unless to much sand in it but still, Should slide right out.
Old 03-14-2007, 09:20 PM
toyaholic's Avatar
just did the job the other day. flat head screw driver will do it. kind of hard to put into words but if you look at it for a sec you'll get it. you just pop the clip over and the box will slide down and out.
Old 03-15-2007, 04:39 AM
old4runner's Avatar
that was it, i tried that before i posted this thread last night...i guess it was just being stubborn
Scotttekoch
09-28-2015 10:30 PM
JPV
09-28-2015 03:15 PM
Rcbc92
09-26-2015 03:00 PM
toyotasaurus
09-24-2015 03:30 PM
Tcsdef
09-07-2015 11:17 PM
Quick Reply: 80 AMP Fuse
