4runner altimeter
Old 11-12-2008, 09:59 PM
94toy4x4fever's Avatar
4runner altimeter
Not to sure on how to set my altimeter on my 4runner! Im new to this kinda thing! So if anyone could clear it up for me and help me out to get this thing set! Thanks
Old 11-12-2008, 10:12 PM
RiCh_90-yota's Avatar
Any pics!
Old 11-12-2008, 10:19 PM
SpecialScottie's Avatar
Are you asking how to adjust it?
There should be a little knob right beside it
Old 11-12-2008, 10:50 PM
stormin94's Avatar
In theory, couldn't you just drive down to the ocean, and set it at zero?
Old 11-12-2008, 11:25 PM
space-junk's Avatar
in theory yes, but he lives in idaho... lol... kind of a waste of gas just to set the altimiter...
(yes, i understand what you meant, im just in a mood to screw around)
Old 11-13-2008, 12:04 AM
Jay351's Avatar
Thread hijack. so I might aswell post this here...
So you can get factory altimeters for 2nd gen 4runners/3rd gen pickups? Are they plug and play?
Old 11-13-2008, 02:55 AM
flashkl's Avatar
I don't know about where to buy them, but the unit is self contained, so you should just be able to duct tape it to your dash
Old 11-13-2008, 03:03 AM
drew303's Avatar
LoL Duct Tape, now that'd look good.
It bolts to the dash quite simply. *not really. You have to remove the dash 'safety pad' as Toyota calls it.. which is in short, the entire passanger side dash. Only real hard part with that is getting the right vent out without destroying it or the pad. theres... if i remember, 3 mounts that fit through factory holes in the dash. You just need to open them up (they're already drilled) then pop the clinometer on, put the nuts on, wire it up, your done.
I put one in my rig awhile ago.
just find out the elevation of your home and set it and leave it. It'll fluctuate a few hundred feet depending on the weather. It's only good for a guesstimate ofcourse =)
Old 11-13-2008, 03:07 AM
drew303's Avatar
yes, yes and no.
They did make em for 2nd gens.. but those are even harder to find and im not totally positive how easy it is to install them. Same with 3rd gen pickups.
but more common are the 86-88 4runner Clinometers. Which also fit the same in the pickups.
The wiring however isn't just hiding under the dash, you have to hardwire it which isnt to hard. I wired mine in with the dash lights so it adjusts brightness same as the dash lights. (ground it to the rheostat)
Old 11-14-2008, 04:55 PM
stormin94's Avatar
The 4WD Tercel SR5's have them too.
Old 11-16-2008, 01:30 PM
Jay351's Avatar
Originally Posted by drew303
yes, yes and no.
Ahh, I figured I would just need to wire in for the dash lights.. I guess the hardest part would be actually finding a clinometer for my gen truck.. Thanks for the info
Old 11-16-2008, 02:06 PM
stagger_lee's Avatar
You should have altitude signs somewhere in your area, or go to a ranger station, they usually know the altitude at that location. Trailheads also might show altitude. Adjust it accordingly using the knob on the left.
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
coreyedwards7611
01-16-2016 06:38 PM
BeMiceElf
10-10-2015 09:40 PM
Poppie51
07-23-2015 05:03 PM
Quick Reply: 4runner altimeter
