4Runner 94' Weak Transmission?
I am having a similar problem. I have a 94 4runner. My problem started after I had replaced the radiator. As of now i have a leak in one of my transmission cooler lines ( in the process of replacing it). The truck shifted fine after it warmed up(not an issue).Now the truck will need to be red lined to move slightly. then it will shift fine afterwards. I have replaced the fluid and the filter(no metal shavings) also I have replaced all of the solenoids. I do have the same problem in 4LO. reverse works great. Any help with this issue will be greatly appreciated.
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
