4 runner is dying
Old Dec 8, 2007 | 08:37 PM
1990Runner's Avatar
Unhappy 4 runner is dying
My truck running worse every day it seems like. but sometimes it runs a little better. This is what its doing, it sounds like its missing, idles fine, poor acceleration, especially rough and shaky between idle and 2800-3000 RPM. I checked my timing around 2000 miles ago and it was 35 DEGREES. i set it at 10 and it helped but like i said, its getting worse and im getting worried about my baby. help please
Old Dec 8, 2007 | 09:31 PM
Jay351's Avatar
Have you pull any codes?
Jump the Te1 and e1 termanel in the gray "diagnostics" box under the hood (passenger side, by fuse box). Turn key to "run" and count the blinks of the check engine light ( pen and paper to write them down)
Old Dec 8, 2007 | 10:57 PM
cobra6syc's Avatar
also check you ignition components! Allways check the weakest link, also known as the cheaper parts! Start with spark plugs, wires, cap and rotor. Hows the fuel pressure? Hows your air filter??
Old Dec 9, 2007 | 06:31 AM
1990Runner's Avatar
i changed the plugs, wires, cap, rotor, air filter and fuel filter( that sucked) 5000 miles back. i didnt know how to check for codes so ill do that today and see whats up.
Old Dec 9, 2007 | 06:33 AM
1990Runner's Avatar
oh, how do i know if i have good fuel press
Old Dec 9, 2007 | 07:43 AM
ozziesironmanoffroad's Avatar
there should be a service port on the fuel rail. question though: is the idle all screwed up, choppy, and uneven? and when you accellerate does it choke and threaten to die?
Old Dec 9, 2007 | 08:18 AM
1990Runner's Avatar
no it idles fine, but when i jump the Te1 and e1 the check engine light just constantly blinks with no pauses. what does that mean. and one thing is that the truck seems to run a little better after its warmed up
Old Dec 9, 2007 | 11:07 AM
Jay351's Avatar
A constant blink means there is no stored codes.
Are you sure you have all your vacuum lines hooked up correctly?
Old Dec 9, 2007 | 11:21 AM
duh. any car will run better once its warmed up.... lol! think about this... when you wake up in the morning, do you prefer waking up gradually, coffee, cigs, w/e, or do you prefer to just get up and go? well, cars like having their coffee and donuts in the morning. lol. i know when i wake up i have to take a shower and have some coffee or i am NEVER wakin up fully. lol
Old Dec 9, 2007 | 11:36 AM
Jay351's Avatar
Truck should run fine when first fired up, albeit it will idle high but thats beside the point.
Old Dec 9, 2007 | 11:49 AM
rowdy235's Avatar
might try running some seafoam through it
Old Dec 9, 2007 | 12:14 PM
1990Runner's Avatar
i did seafoam like 2000 miles back and it did help a little. so ill check the vacuum lines. what makes me nervouse is my haynes book says it could be a bunch of stuff with the EFI. all of which could be expensive and i just took a 1500 dollar hickey with the clutch/steering gear job.
Old Dec 15, 2007 | 09:09 AM
1990Runner's Avatar
i dont have a good selectoin of tools to work with or the patience to deal with elec problems. i broke down and took it to my mechanic and so far all he has found is a bad injector. hope thats the end of it. ill find out monday. excited to see how much my gas milage will improve from this
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
coryc85
Jul 6, 2015 04:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
