3vze timing belt help
Old Jan 12, 2008 | 09:49 AM
ccannon222's Avatar
I am installing a long block in my wife's 95 4runner and I am a little confused. I am currently installing the timing belt. I put everything on as per the FSM. Crank at TDC, both cam pully marks at 12 o'clock. I set the t-belt installation marks to match the mark on the bottom of the crank, and the two 12 o'clock marks on the cam. I installed the tentionor and put the crank pully on. I then turned the motor over 2 rev to check the timing as per the FSM. After doing this, the top two cam marks are back at 12 o'clock, crank at TDC. However, the installation marks on the belt are no longer matching the cam pully marks.
Should they?
Thanks
ccannon222
Old Jan 12, 2008 | 10:07 AM
toytech76's Avatar
Check your crank pulley. I've had several pulleys seperate. The rubber portion of the balancer seperates from the pulley and the timing mark moves on the crank pulley making your timing off
Old Jan 12, 2008 | 10:50 AM
eric-the-red's Avatar
Should they?
Thanks
ccannon222
No, the marks on the belt are only for initial setup, they won't match after turning the 2 revolutions. As long as the marks on the cam and crank pulleys are in the right spots you're good to go.
Old Jan 12, 2008 | 11:21 AM
ccannon222's Avatar
Thanks for the help. My crank pulley if good. I double checked the marks on the timing gear on the crank and it is at TDC.
I didn't think that the installation marks would stay on the pulley marks but I wanted to make sure.
I didn't want to mess up my wife's new motor.
ccannon222
Old Jan 12, 2008 | 07:43 PM
GSGALLANT's Avatar
x2. They are just for initial installation. If you have time to kill and you keep rotating the engine for a while, the lines will eventually line up properly again. It takes quite a few revolutions, though.
Old Jan 12, 2008 | 07:59 PM
Green93's Avatar
That messed with me when I was putting mine back together as well. The marks move one tooth to the left after every revolution as the others have said.
Jason
Old Jan 13, 2008 | 03:03 AM
pete f's Avatar
"pete f passed away quietly in his sleep on July 13, 2008
I had to tear down my 3.0 last week because I left the wrench on crankcase bolt after a distributor change and on testing for spark the wrench caught in the fan and backed the bolt out of the crankcase. The mechanic that did my timing belt did not install it with the marks on the new belt . At first I didn't see the marks so I used a marker and made my own. Then I saw the marks and they were way off. When I was checking the belt for wear I turned the crank two full revolutions and I was back to 0*btdc the marks lined up on the pulleys perfect I had to make two more revolutions and my marks I made with the markers had moved four grooves each . I put it all back together and now the truck is running great after I chased down some gremlins.https://www.yotatech.com/3-0-ecm-89-pick-up-93-fsm-131904/
The cam pictures are on the 2nd page.
Old Jan 13, 2008 | 10:05 AM
4x4CPOSEADOG's Avatar
X3, cam pulley marks are just for initial set up. You're doing good.
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
