3vze Help
Old Nov 18, 2007 | 03:49 PM
jdcarnathan's Avatar
3vze Help
I Was Installing My New Oil Pump On The Rebuild And Forgot To Put The O-ring In Between The Block And Pump On The Output I Guess. But It Has Rtv Everywhere Around It. And The Motor Is Already Back In The Truck. Should I Leave It And Hope The Rtv Holds Or Should I Pull It And Fix It. Thanks, Also Is There Both A Front And Rear Seal On The Oil Pump. Thanks
Old Nov 18, 2007 | 04:01 PM
INFINITY's Avatar
depends on how lucky you feel. personally i would pull it and put the gasket and rtv in there just so i would not have to do it if it blew
Old Nov 19, 2007 | 05:00 PM
bumpp
Old Nov 19, 2007 | 05:31 PM
nate V's Avatar
How much is the o ring.....
It might be worth your time to do it correctly
bump
use o ring and the rtv
Old Nov 19, 2007 | 11:42 PM
idanity's Avatar
if you do leave it, would you ever take a long road trip w/out becoming worried?
i would at least add a few "low oil" lights w/buzzers and a auto shutoff. but with that amount of work, why not just re-do it correct.
even if you re-do it, and find that there is an o-ring on there, you will have the experience of re-checking your own work.
its worth it in my book.
Old Nov 20, 2007 | 02:35 AM
TNRabbit's Avatar
It's definitely needed!
Old Nov 20, 2007 | 06:58 AM
MonsterMaxx's Avatar
Needed. Do it right.
Old Nov 21, 2007 | 11:35 PM
i forget since it is a 3vze can you remove the oil pump with out dropping the pan
Old Nov 22, 2007 | 12:22 PM
89pickupsr5's Avatar
you have to take the oil pan off and i would definitly do it, it's worth it
Old Nov 22, 2007 | 04:57 PM
idanity's Avatar
not sure if you can get the oil pan off easily or not, but i do know the bmw needs to raise the engine 3 inches to remove it, some have made a pulley system and loosened the motor mounts for a much easier (and faster) job of it.
hope that helps.
*be happy you remembered in time
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
