3vze Engine Ground
Old 02-09-2010, 03:00 PM
alil2cul4u's Avatar
3vze Engine Ground
Can you guys tell me where the ground strap/wire is on the engine and where its mounted at on the car? I think there is a possibility mine is loose. Please get back to me as soon as possible thanks
TIA
Julian
Old 02-09-2010, 03:37 PM
Fink's Avatar
Have you tried searching?
Fink
Old 02-09-2010, 04:24 PM
pb4ugotobed's Avatar
Below your AC compressor is a big one. Another one mounts to the driver side exhaust manifold. Another one is on the top of the intake plenum to firewall....
Old 02-09-2010, 07:57 PM
alil2cul4u's Avatar
Yes I did search Fink I even looked in my FSM but couldnt find it. Thanks pb4ugotobed, but what is the intake plenum? sorry if that is a stupid question. and where is the AC compressor?
Old 02-09-2010, 08:04 PM
alil2cul4u's Avatar
Hey, I found the one on the Intake Plenum, and the exhaust Manifold. But I do not know where the AC compressor is.
Old 02-09-2010, 08:10 PM
dntsdad's Avatar
on bottom left under the power steering pump/resevoir(where you add power steering fluid).
It has a belt on it to spin?
You have ac correct? Otherwise there will not be one there. LOL
Old 02-09-2010, 08:30 PM
alil2cul4u's Avatar
LOL, yes I do have AC. I just wasnt sure where Id find the compressor on here. The only car I can ever remember doing anything with the compressor on was a 84 BMW and I was only like 7 at the time when my dad and his friend was rebuilding the car! I have been having problems with it acting as if it is going to stall and still trying to find the problem, I have replaced multiple things ( you can find that thread here : https://www.yotatech.com/forums/f116...stalls-201945/) I havent been able to go buy the multimeter yet but hopefully can at the end of the week! I have however checked the ground I could find and those arent the problem. I will check the other one tomorrow, Im also going to take the Ignition coil off and go have it tested to see if that could be my problem! Do any of you guys know how I can test the Ignition Module?
Sandman
07-14-2015 12:36 PM
88yodabasket
07-13-2015 01:32 PM
smiley52
07-11-2015 05:16 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 3vze Engine Ground
