3vze Crank pulley removal
Old 05-27-2009, 05:13 PM
jasonbrink's Avatar
What puller do you guys use to get the crank pulley off? I was gonna try the pry bar method, but i really don't want to end up spending more time and money due due damaging the harmonic balancer.... Does this harmonic balancer puller look about right for the job? I am hoping to just find one of the "loan a tool" freebies from Autozone that will work for this.
http://www.autozone.com/autozone/ino...ersSpecialized
thanks everyone!
Jason
Old 05-27-2009, 05:31 PM
TNRabbit's Avatar
That'l work; you can get one cheap at Sears...
Old 05-27-2009, 08:17 PM
bugs1961's Avatar
Jason,
You may not need the puller if the pulley isn't rusted in place. Toyota 3.0 crank pulleys aren't pressed on and every time I've taken one off, I was able to just slide it off with my hands. I coat the inside of the pulley and the crank nose lightly with engine oil before installation and it will slide on easily by hand and come off next time with no trouble.
Bugs
Old 05-28-2009, 06:29 AM
GSGALLANT's Avatar
Yeah, mine came off no problem by hand.
Old 05-28-2009, 06:53 AM
buckz6319's Avatar
I will know if my crank pulley will come of with ease in 2weeks......I purchased a harmonic balancer puller from O'Rilleys for $16.00 and hope it will work for me when the time comes
Old 05-28-2009, 07:18 AM
Staff
DeathCougar's Avatar
That balancer puller is EXACTLY what you need. Just remove two of the bolts from the outer PS pump pulley, screw the longer bolts from the kit in there, and it works like a charm.
I have that exact same puller setup.
sandyota
02-04-2021 11:16 AM
yoterr
07-24-2015 04:29 AM
CanRunner
07-20-2015 01:29 PM
redneck17
07-17-2015 07:44 PM
dinks07
07-15-2015 05:34 PM
Quick Reply: 3vze Crank pulley removal
