3vze 1988 into 1993
Old 04-17-2015, 01:17 PM
vweggie's Avatar
3vze 1988 into 1993
I've got an '88 pickup that I'm selling because the rear frame has rusted out. A friend wants to buy it because he drowned his '93 pickup. Any issues with transplanting the motor from the '88 into the '93? Thanks!
Both trucks are 4x4, blue and have manual transmissions.
Old 04-19-2015, 11:04 AM
vweggie's Avatar
bump, anyone know if the 3vze is a straight forward swap from a 1988 into a 1993?
Old 04-20-2015, 01:18 PM
red-pick-em-up-truck's Avatar
I am in the middle of the very same swap. ..
short answer is: not really.
longer answer: if both vehicles are side by side it will be easier to do. Motor mounts are different, AC mount, wiring and sensors as well as the distrbutor/coil are all different... It is do-able but it is not a total plug-n-play swap.
Old 04-25-2015, 08:04 PM
vweggie's Avatar
Thanks!
Old 04-28-2015, 11:45 AM
Tireman922's Avatar
I did the Swap the opposite way, but it was a 3.0 out of a T100 2wd. It is a lot of part swapping but is doable.
Old 04-28-2015, 12:49 PM
How did you address the different distributor drive support issue? Or did you change heads as well?
Zach_trun
11-17-2015 07:56 AM
_Nicco_
09-21-2015 03:06 PM
LotOMiles
09-14-2015 11:45 PM
seab1209
09-03-2015 05:41 PM
pplusent
09-02-2015 11:56 PM
Quick Reply: 3vze 1988 into 1993
