33's & Speedometer..
1 Post
If you can't afford to buy a GPS unit or re-gear your truck:
http://www.1010tires.com/tiresizecalculator.asp
that is for you. I have (thanks to college tuition fees) a little chart in my truck taped up so that I can have the correct speeds visible.
When my speedometer says 85 km/h, I am going 100 km/h
in my experience, when you throw an auto into the mix you usually have to step up to the next gearing set. So 31=4.56, 32=4.88, 33=5.13. That is why some toyotas came with 4.56 or 4.88 stock gearing, its those with auto tranny's and 31'' tires as the factory setup.
