3.4 exhaust manifolds on 3.0 heads?
Old 03-08-2006, 10:52 AM
DirtCheap's Avatar
Aren't the 3.4 exhaust manifolds interchangable with the 3.0. I, can't remember if they will work on the 3.0?
Anyone?
Old 03-08-2006, 12:09 PM
Weasy2k's Avatar
it appears they do....i got hte urge to check AFTER i remounted the 3vz-e heads back on the engine...i got some pcitures tho so once i get them off my camera i can see.
Old 03-08-2006, 12:22 PM
DirtCheap's Avatar
Pics would be GReat, if you could post or email them I, would apreciate it.
How well do they line up with the ports and the studs, any problems mounting?
Old 03-08-2006, 12:27 PM
Weasy2k's Avatar
ill find out shortly
Old 03-08-2006, 01:29 PM
Bumpin' Yota's Avatar
Bookmarked!!! lol
Old 03-08-2006, 10:25 PM
CoedNaked's Avatar
If the 3.4 exhaust manifolds will work on the 3.0, let me know because I think I will blow my load. They are a much improved design over the 3.0.
Old 03-10-2006, 07:23 AM
DirtCheap's Avatar
A friend who is a Toyota mechanic tried the 3.4 exhaust on the 3.0 and it would not fit. That would have solved a lot of problems if it would have worked.
Old 03-10-2006, 09:36 AM
Weasy2k's Avatar
did he say what didnt match up?
Old 03-10-2006, 09:55 AM
DirtCheap's Avatar
I, didn't get into specifics with him he was in a hurry. Did you try it yet?
Old 03-10-2006, 01:12 PM
Weasy2k's Avatar
i didnt get a chance to try cause i put htem on the truck without testing them i forgot...i have 7 car/trucks lined up here for big work so i totaly forgot...i got pictures tho so ill see how they match up
Old 03-12-2006, 10:26 PM
chopps's Avatar
5vze manifolds wont work on a 3vz-e heads vise-versa. The 5vzfe have off set bolt pattern while the 3vz-e manifolds have a verticle pattern.
Old 07-29-2011, 05:46 PM
ckblum's Avatar
Sorry to revive this old thread. Has anyone tried modifying 3.4 headers to fit a 3.0? If the ports line up could you just re-drill the flanges or something? 3.4 headers are just easier and cheaper to find so it'd be cool to be able to adapt them.
EDIT: What about 3.4 heads onto a 3.0 block? Maybe possible cause you can drop a 20R head on a 22R block, so maybe they keep the heads similar in the V6 family.
Amer
3.4 Swaps
19
06-05-2017 10:43 AM
coleypull15
11-03-2015 07:41 AM
tj884Rdlx
08-28-2015 12:04 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: 3.4 exhaust manifolds on 3.0 heads?
