3.0 Idle problems solved.
Hope this thread helps those with troubles with there 3vze. Took my truck to the Toyota dealership and had it inspected and is gettting fixed as I write this. My injectors are getting replaced along with new grommets for them since the previous ones were bad and were spraying in the incorrect area. Lower intake tube was cracked causing air to leak in, replaced. The spark plugs I had were also inccorrect, never buy from autozone. The fuel pressure regulator was bad also getting replaced. this all was causing my truck to idle at staggering low rpm's, even stalling. So I hope this helps those with low idle 3vze's.
lol -- I don't know if that helps me or scares me. Mine doesn't stall but it gets pretty close. I probably just have to turn the idle screw a little, because it sits at about 600rpm idle and I think 850 is normal. At least I hope all I have to do is turn the idle screw. that looks like it would be $$$$$
ZONAYODA
07-13-2015 07:17 PM
Jnkml
07-06-2015 01:20 PM
