2nd gen runner rear axle link broke!!! how important???
Old 03-02-2009, 12:46 PM
tc
tc's Avatar
Switching to leafs won't exactly eliminate this problem, and bring on a whole host of others - axle wrap, wheel hop, etc.
Old 03-02-2009, 12:52 PM
newman's Avatar
my problem with the stock links is i can't get much travel out of them, and they're weak. i'm in the minority on these forums, i like to run my truck around the desert at high speeds, hence why i break stuff a lot leaf springs will be a cheap solution for me to get more travel out of my rear end.
Old 03-02-2009, 01:03 PM
tc
tc's Avatar
The links don't limit the travel. Molly's truck flexed like CRAZZZY with the stock links, long shocks, and FJ80 springs. IMHO, it does not flex as well since we swapped it to 63" Chevy's.
For high speed, I would definitely want the link suspension. Redoing the links is the same or less work than doing the leaf swap if it comes to that.
Check out "Chaplain"s 3rd gen dezert build - rear suspension is practically identical to 2nd gen.
Old 03-02-2009, 02:55 PM
rock slayer's Avatar
ok i am all welded back up turns out the guy i have been working for had a lincoln in the back of his garage gonna gusset when i can find some 1/4" steel but its on for now
Old 03-02-2009, 03:56 PM
  #25
space-junk's Avatar
hey, tc... do you have all the specs for the 4 link that you did??? i dont want to do anything crazy, but theres no one that makes an upgrade for the rear susp. and yours looks professional...
Old 03-02-2009, 04:47 PM
  #26
seaofnames's Avatar
I know mines a 3rd gen, but one of mine broke due to rust. I inspected the other 3 mounts with a flashlight and mirror(on a hoist as well) and noticed some of the steel was quite thin, so I just went and got a used low mile axle housing for 300 bucks. I was lucky because the elocker diff is a lot harder to find. The new axle housing looks really good and came from a 99.
Edit: I drove my truck pretty hard for about 2 months before I replaced it.
Old 03-02-2009, 05:24 PM
  #27
tc
tc's Avatar
It's in the link I posted above. If you PM me your email addy, I'll email you the actual file.
Old 03-02-2009, 05:38 PM
  #28
bigt's Avatar
you selling your old elocker diff?
Old 03-02-2009, 05:39 PM
  #29
seaofnames's Avatar
Sorry, I replaced it in the spring, the housing went to the scrap yard. I guess I could have sold it on here or something.
D'oh!
4x4-runner
02-26-2017 06:42 AM
marcusSRG
06-27-2015 07:13 AM
Niameyrider
06-25-2015 05:50 AM
infinityisfive
06-16-2015 06:51 PM
95Runner
06-09-2002 08:56 AM
Quick Reply: 2nd gen runner rear axle link broke!!! how important???
