2nd Gen LSD Diff question
'91 4runner knocking
I'm giving an old, cherry 4runner new life! After rebuilding the motor, messing with fuel injectors and timing, (throttle position sensor still off) I replaced the cv boots. Test drove about 250 miles, now I have a knocking noise on the driver's side. Front differential is leaking oil everywhere. I need specs and suggestions, please! My Haynes manual doesn't have anything on the front differential, and alldata not much help either.
What did you end up doing with your diffs?
**Note: TruTrac is a limited slip, not a full locker. It is a full carrier design though, so it should work in your application.
Hi tc,
I assumed the risc of being wrong and supposed my stock LSD would be compatible to a V6 3rd and voilà, I was right. I've the same carrier as a V6 but LSD. So I had to choose a locker to replace the whole carrier and I choose a Detroit Soft Locker V6 style.
The install was cheap and it's nice how it works.
In front I've a standard 7.5'' diff so I put an Aussie Locker in it.
David
David
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
coffey50
07-28-2015 10:55 AM
Steven.m.paulk
07-24-2015 01:44 PM
Steezy96yota
07-06-2015 10:00 AM
