2nd Gen Aftermarket Gauge Locations?
Old 06-02-2008, 09:19 AM
qdude79's Avatar
Got two 2 5/8 gauges I want to install. Anyone have a good place for them? Thought about the panel under the cig/ashtray, but they would actually point down somewhat. Other ideas/experiences? Pics would be great...
Qdude
Old 06-02-2008, 05:18 PM
norcalsvx's Avatar
i run a pillar pod from jeff mosk
Old 06-02-2008, 05:22 PM
Jay351's Avatar
How do you like that piller pod Norcalsvx? I want to order one when I get some "mess around money" together.
Thinking of running - Oil pressure, volts and water temp guages.
Old 06-02-2008, 05:34 PM
mt_goat's Avatar
https://www.yotatech.com/forums/f116...acement-97075/
Old 06-02-2008, 06:35 PM
qdude79's Avatar
Thought about the pillar idea, two things prohibitive: 1) Both gauges are mechanical (vac/tranny temp). Not impossible, but difficult. Second, I only have/want two gauges, Mosk sells 3 gauges for my app. Being that it's an auto, I'm considering something behind the shifter, aimed at the driver.
Old 06-02-2008, 09:08 PM
norcalsvx's Avatar
i like it fitment was great and i'm happy with it, i'm going to get some ele. autometers (water temp/oil pressure/ a/f ratio) pretty soon.
for a auto you can always get a tranny temp gauge for your 3rd gauge
Old 06-03-2008, 05:07 AM
breknraj's Avatar
If you have a single DIN radio, you can put up to three guages into the available DIN slot, with a little finesse. You can also get a small piece of PVC pipe in the right size to fit the housings, then cut spacers that are square on one end, and slightly angled on the other, so that you can tilt the guages toward the driver.
Old 06-03-2008, 05:23 AM
mt_goat's Avatar
Yeah the 2 1/16" gauges fit the DIN slots good, the OP said he has those big 2 5/8" gauges though.
The Perrin gauge pod fits 2 of the bigger 60mm gauges.
http://www.nyxracing.com/perrin-univ...od-p-5055.html
Old 06-03-2008, 07:46 AM
qdude79's Avatar
I'm considering giving Breknraj's idea a shot. For the cost of PVC, worth a try! Thanks!
PS- Anyone done this? What were the results?
Old 06-03-2008, 07:54 AM
mt_goat's Avatar
http://www.gadgetonline.com/Gauges.htm
Old 06-03-2008, 08:39 AM
Workhorse's Avatar
Wow Lots of great ideas on that site thanks Goat! *gears are turning* *smoke rolls out my ears* dang oil pressure i needed a gauge..
Old 06-03-2008, 09:12 AM
mt_goat's Avatar
Here's Gadget's latest gauge install:
http://customtacos.com/forum/showthr...ghlight=gauges
Old 06-03-2008, 07:34 PM
breknraj's Avatar
My bad, not noticing the larger size!
You might be able to fab an housing to fit in the space below the ashtray that would angle the guages up, so that you can read them. You might have clearance issues with the shifter, though.
Old 06-03-2008, 08:45 PM
RobD's Avatar
Time permitting, I'm going to be prototyping/building a two gauge pod for the dashboard, above the vents, out of birch and fiberglass.
Old 06-03-2008, 09:01 PM
Hayes's Avatar
That's what I would do
calderp
Engine Swaps
08-16-2016 05:15 PM
gary4runner
09-24-2015 12:53 AM
calderp
07-27-2015 09:58 AM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 2nd Gen Aftermarket Gauge Locations?
