2nd emissions attempt...failed!!!!!!
Old 04-18-2009, 11:02 AM
yota4life6's Avatar
hey guys..
after new 02's, plugs, wires, air filter, and a solid running truck.. I failed emissions again this morning... I triple checked vaccuum leaks as well..
heres the deal... legal limit for CO is 1.29-ish... I WAS AT 7.89!!!! Literally everything else is new on the truck, even a rebuild 8k miles ago...
I have a new cat converter in the garage.. Guess I should throw that on too?? WOuld the cat take it from 7.89 to 1.29?
thanks in advance
Neal
Old 04-18-2009, 02:23 PM
desertcox05's Avatar
did you ck you egr valve? the small sense line can get clogged with carbon and the egr will not operate properly
Old 04-18-2009, 05:54 PM
abecedarian's Avatar
EGR shouldn't cause high HC or CO. A new converter might bring it down to spec.
kawazx636
10-06-2021 03:03 PM
dbollier123
09-29-2015 05:23 PM
charlie_fong
09-27-2015 10:06 PM
Keithstoyota
09-27-2015 07:29 AM
Quick Reply: 2nd emissions attempt...failed!!!!!!
